Favorite Features or Mods
Posted: Sat Aug 06, 2016 3:36 pm
So with 200 hours on my plane in just over 2 years, and a couple of 1,100 mile trips, I've come to appreciate some of the per-plans features of my Sonex, and also some of my own modifications. I'll show you mine if you show me yours...
1. Fuel sight tube on the panel, per the Sonex plans. You ALWAYS know how much fuel you have! I can watch it every second of my flight. Once the fuel disappears behind the panel I know I have 1 hour of fuel (if I run it to zero). So I figure 15 minutes after the fuel disappears I should be thinking about landing. I calibrated mine in two colors: black for gallons in level flight, and red for gallons sitting on the ramp. I have a Gold Cube fuel flow sender, but it's worthless.
2. Trim lever, per the Sonex plans. It's infinitely adjustable and you know where it is at a glance.
3. Battery charge/jump port on the bottom of the cowl. It's completely protected and water tight, and takes 2 seconds to hook up to a battery charger. A quick disconnect inside the cowl pulls apart when I take off the lower cowl.
http://www.mykitlog.com/users/display_l ... 069&row=43
http://www.mykitlog.com/users/display_l ... 070&row=42
4. Entire center section of my instrument panel comes off in about 4 seconds by pulling 4 piano hinges. I can reach everything behind the panel without having to get upside down. I swapped out a radio the day before coming to OSH, in 13 minutes (I timed myself).
http://www.mykitlog.com/users/display_l ... 450&row=75
http://www.mykitlog.com/users/display_l ... 561&row=74
http://www.mykitlog.com/users/display_l ... 7932&row=1
5. Extra bracing/gussets on the rear canopy bow structure. Much stiffer.
http://www.mykitlog.com/users/display_l ... 271&row=13
6. Fuel vent at the bottom of the cowl. No fuel on the windscreen in bumpy conditions, after overfilling the fuel tank, or during aerobatics. Ask me how I know all those conditions will spill fuel out the top-mounted vent!
7. Lowered seat mod (not an option for the Waiex). You can always add cushions. You can't remove aluminum!
8. EarthX battery. Works better than my Odyssey, and saved me 11 pounds!
