canopy screen to control sun brilliance
PostPosted: Fri Jul 01, 2016 10:51 am
by Ed Perkins
I have an 8" Samsung Tablet with the Avare Software on it serving as my primary navigation system. I tried it out this week and found out that the sunlight coming into the canopy is so bright I can't read the tablet screen and therefore can't utilize this system.
QUESTION: Where can I purchase some kind of screen material to decrease the sunlight coming into the cockpit so I can read my tablet Avare software? Is this material able to be moved around AFTER install? I suspect I may need to move it to some extent to deal with where the sun is setting. I have seen something advertised in I believe Iowa several years ago that was a screen material that went on the inside of the bubble canopy.
Thanks for any help or suggestions.
Ed Perkins, Sonex #371, Appleton, WI
Re: canopy screen to control sun brilliance
PostPosted: Fri Jul 01, 2016 11:45 am
by kmacht
Walmart or any auto parts store will have what you need. They are called window clings. They come in different sizes but all of them are basically a shaded plastic type of material that will stick to the canopy by static cling. They are meant to be used on a car window to keep the sun off of little kids in the back seat. I bought two 15x15 pieces for less than $15 and they work awesome. Moving them around in flight is possible but it is easier to do if you have a passenger to move them or you can turn on an autopilot as it usually takes two hands to move and position them into place. Here is a link to what I am referring to:
http://www.walmart.com/ip/2pcs-Black-Wh ... m/50345504
#554
PostPosted: Fri Jul 01, 2016 1:05 pm
by rk2436
Google Koger sunshade,,,lots of RV's use them and they have one that fits the Sonex,pricey but it works
