Spark Plug Wires
Posted: Sun Apr 03, 2016 6:33 pm
Has anyone purchased aftermarket spark plug wires from a performance shop and can recommend?
(for the lower plugs)
A Forum for Sonex Aircraft Builders and Enthusiasts
https://sonexbuilders.net/
Mike, do you have Part Numbers or they just generic. I'll also check out O'Reilly's.
Looked at the top Wires and they appear to be permanently attached ??
Mike, have you run the stock wires to tell if the ignition noise changed with the new wires?
rhw5548 wrote:Has anyone purchased aftermarket spark plug wires from a performance shop and can recommend?
