Mike, do you have Part Numbers or they just generic. I'll also check out O'Reilly's.
Looked at the top Wires and they appear to be permanently attached ??
I will have to go out to the hangar and get the part numbers as the top and bottom are different numbers.
No, they are not permanently attached. I will grab one of my 3 old magnetrons that failed and take pics of how to replace them.
Mike, have you run the stock wires to tell if the ignition noise changed with the new wires?
Yes, I was chasing radio noise demons for a long time, which was the reason I decided to try them. These wires helped the noise immensely. I still get a little noise at full throttle but not nearly as bad as before. At lower RPM's I get very little, if any, noise now. Plus I think they look cool. I went with the yellow because that is what was in stock at the time and I didn't care much if they were yellow, red or blue...
