by Darick » Tue Mar 22, 2016 10:51 pm
I searched but couldn't find posts on the motor mount not fitting easily into the fuselage mounts. The bottom motor mount outside dimension is 33". The fuselage distance is SLIGHTLY LESS than 33", (the mount must fit inside the fuselage brackets). It seems the round landing gear receivers, which extend about 1/4" past the square part of the mount, needs to be filed off so they will fit better into the generous radius of the fuselage mounting angles. I'm not sure at this point if this will totally solve the problem but it will help.
I can't see how I could have made the width (33") too short since this distance has been determined by the prepunched holes in the bottom skin.
Help with any suggestions please?
Darick
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
