by DCASonex » Sun Jan 31, 2016 7:15 pm
Steve and Roger,
I owe you both double. Having bad case of cabin fever, an adequate supply of raw material, and a decent lathe, decided to have a go at making one of those. I looking at neck of my fuel tank to see just how far down I should locate my o ring, realized that the neck is so short that the inside starts to flair into a radius about 1/8" down. The wine bottle stoppers bulge well below that. No wonder I have had problems getting a decent seal. Only had about 3/32" clear from top of the bottle stopper to underside of fuel door, but found a 3/16" square cross section O ring from an old oil filter, and placed that under rim of one of my bottle stopper caps to raise it to position the bulge more up into the neck. Big improvement. Was able to grinding off enough material from top of the brass cam to still clear the fuel door. Great, but did not cure the cabin fever.
Never being one to leave well enough alone, decided to see what I might do differently for your O ring type fuel cap design. Since was always losing setting and having to re-adjust the wine bottle stopper's screw when filling tank, thought why not just make it screw tight. This of course actually makes design more complicated with need for some means to key the upper and lower halves to prevent rotation, and a tab to prevent entire unit from rotating. Decided to machine the outside tab as part of the top plate, which meant it would look like a frying pan handle and required setup in 4 jaw chuck. (I did mention having cabin fever) Made bottom half which is the forcing cone of Delrin because it is light, has good fuel resistance, and I had a short 2" dia. bar of it. Located center-line of O ring only 7/32" down from top of neck. That was far enough to put it into the beginning of the tanks inside radius so that there was no way tightened cap could be knocked or vibrated out, but not so far in as to require expansion beyond what is achievable with the design. Made 15 degree angled seat on top plate so that it would be pulled down tight to tank as O ring was pushed out by the 60 degree taper on bottom forcing cone. All SS hardware, with small O ring sealing center bolt, and a small screw and washer into top end to keep unit from accidentally being completely unscrewed. Knob is cut down aluminum 4 arm star type, and a small peg on underside of fuel door comes down in large space between arms to insure that knob does not unscrew in flight.
Seems to work. Feels like it seals tight, quick to install or remove, with just two turns of knob (18 threads per inch on center bolt), looks way better than the wine bottle stopper, and weight is about the same. Probably could have done without the frying pan handle, but that also provides a place to tie my cable. (Once taxied away from fuel pump without the cap, now it is tied to plane like mittens on a kid.)
So now have two good working fuel cap options, but like the feel of the way the new O ring unit tightens down, and it just looks more professional.
Thanks again, Now to clean up big mess of aluminum, stainless and Delrin turnings and chips from shop. No flying weather yet, so will see about replacing that old 4 jaw chuck which likely dates from WWII, like my "newer" lathe (old one dates from about 1890, and was also used on small parts of this project.)
David A. Sonex TD #1327, CAE 3300 #0004
