Batteries at Oshkosh
Postby jjbardell » Thu Jul 30, 2015 12:50 pm
While at OSH, I saw several battery options. I was curious what everyone recommends if you were to be buying new as part of your build.
One in particular stood out, due to its lightweight and size: EarthX LiFePO4 Battery.
Model Price Nominal Volts Ah
(1C rate) Crank Amps (PCA/CCA) Weight Case Size (L x W x H)
ETX12A $169 13.2 4 220/135 1.3 lb (.6Kg) 4.5” x 2.6” x 3.7”
ETX18B $219 13.2 6.2 340/230 2.2 lb (1.0Kg) 5.3” x 2.6” x 4.1”
ETX24C $259 13.2 8 420/270 2.6 lb (1.2Kg) 5.9” x 3.4” x 4.5”
ETX36C* $349 13.2 12.4 680/320 3.9 lb(1.8Kg) 5.9” x 3.4” x 4.5”
ETX680* $379 13.2 12.4 680/320 3.9 lb (1.8Kg) 6.5” x 3.1” x 6.6”
Any thoughts on these or have other recommendations for a light, powerful battery?
Josh
N83LJ - Sonex #0864 (SOLD)
jjbardell
Re: Batteries at Oshkosh
Postby JT1974 » Thu Jul 30, 2015 3:24 pm
I stopped by the EarthX booth at Oshkosh and the salesperson told me that their batteries had internal circuitry that would prevent the battery from being discharged to the point where it would damage the battery. That's something to consider as LiFePo4 batteries can become paperweights if they are discharged below a certain level.
Jason T
Onex 182
JT1974
Postby radfordc » Wed Aug 12, 2015 10:49 am
I purchased a EarthX battery specifically because of the safety device that prevents over discharge. It may have paid off today....I found that I had left the EIS switch on after flying last week and the battery didn't even have enough voltage to turn on the EIS screen. I plugged it into my charger and it seems to be charging OK.
Postby vigilant104 » Fri Aug 14, 2015 8:54 am
The idea of saving 8 founds by swapping my lead acid battery for LiFePo is attractive. But folks with a light engine (non-turbo Aerovee, Jab 2200) may find that there's little useable improvement in useful load due to CG factors. My plane, with two aboard, is already biased a bit toward tail heavy, and the full 40 lbs can't be put in the baggage area or I'll exceed the aft CG limit. While losing 8 lbs of battery weight improve climb performance a tiny (imperceptible) bit when flying solo, it would decrease the amount of baggage I can carry. I'm sticking with lead acid (AGM) technology for now . . .
Mark Waldron
Aerovee, Trigear
vigilant104
Postby Judoka5051 » Sun Sep 06, 2015 2:18 pm
I had the same problem (different plane though, RV8A) With the light battery I had an aft CG with a backseat passenger over 160. I moved whatever I could forward. The biggest gain was from moving the ELT forward. Those little suckers are heavy!
Judoka5051
Postby mike20sm » Mon Jan 18, 2016 8:55 pm
Standard Sonex kit #1692
preparing workshop for arrival
http://websites.expercraft.com/mike20sm
mike20sm
Postby fastj22 » Mon Jan 18, 2016 9:20 pm
All you kids rushing to get the new lithiums from Sonex, care to sell your old school battery to someone who still needs the weight up front? My Odyssey is reaching its life end and will be needing a fresh one.
Postby jjbardell » Mon Jan 18, 2016 10:11 pm
I have the 680. I have to say it's incredible. I have it mounted on it side so it slides straight out the left side of the plane with the earthx battery case. The safety circuit saved me once already. And it cranks really well. Being a turbo Tri gear it's a nice 11lb knocked off the front.
jjbardell
Postby mike.smith » Mon Jan 18, 2016 11:38 pm
The company line:
https://www.youtube.com/watch?v=wzuysON9ey8
Certainly sounds attractive, other than the price. Almost 4 times the cost of the Odyssey.
Postby Bryan Cotton » Mon Dec 19, 2016 11:03 pm
How many CCA is required for an Aerovee? Is the ETX12A enough battery?
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot] and 86 guests
