by kevin814 » Thu Jul 09, 2015 10:58 pm
I have 530 hours on my old solid lifter 3300, and am finishing a mini-top end. Honed the cylinders, new rings, lapped the valves, replaced some orings, etc. The engine didn't really need it, but I was going to replace some leaky cylinder base orings, and got a case of the "while I'm in there" and wanted to do a few mods. I think most engines if cooled properly can make it to 1000 hours, even if that means lapping the valves once or twice before you get there. My compression was still good, and I fully expect it to go over 1000 hours before I need to open it up again, fingers crossed.
I would be hesitant to buy one of the earlier hydraulic engines. Lots of potential headaches. The new ones seem decent, but if I were buying new I'd go for a Camit. It's an exact replacement for the Jabiru, but has been refined and beefed up, and all the major problems have been addressed. The Jabiru has had many changes to fix engineering problems, then this creates new problems, and they change it again. Maybe they got it right this time, but the jury is still out.
Another benefit of the Sonex/Waiex is the fuel savings as you have noted. If you calculate the difference in fuel burn by the number of hours you fly a year, that could add up. Hull insurance on a cheaper plane might save you money too.
In the interest of trying to "appear" objective, I do think the RV's are beautiful planes, and I like the idea of more passenger space, although most of my flying is by myself. I have a center stick, so I sit in the middle and it is very spacious. I also think the certified engines are more reliable, and require less care. Better for those that aren't very mechanically inclined, and just want to turn the key on and go.
Either way you're a winner, both planes are great, and if you have the ability and the means to fly, that is what matters. Lucky us!
Almost forgot to gloat......... last year when it was cool out I ran full bore (with wheel pants) and squeaked up to 180. Very stable. Lowered the nose a little and hit 200, still stable. I'm no Chuck Yeager, so I gingerly backed off the throttle, and flew home with a grin on my face. I heard of a Sonex owner who accidentally went over 250, so the story goes, without flutter, and lived to tell about it.
Kevin K.
Cincinnati
Sonex 130 Taildragger, Jab 3300 w/Rotec TBI, 6" tailwheel,
