Gear legs
Gear legs
Postby rkurian » Sat May 16, 2015 3:53 pm
For those of you who have had to have your gear legs straightened, where did you get it done, and about how much did it cost?
A hard landing bent the left main gear on my tri-gear sonex, and I want to see if I can get it straightened instead of having to buy (and drill) a new one.
Thanks in advance.
Ray
Ray Kurian
Sonex 612 (N115DM)
Plans Built
Trigear, Aerovee, Dual stick.
First flight 4/11/2015
rkurian
Re: Gear legs
Postby Bryan Cotton » Sat May 16, 2015 4:01 pm
Ray,
I haven't had a chance to bend mine yet. If I did I would look to the EAA chapter for somebody with a hydraulic press, or use it as an excuse to go to HF and buy one. Alternatively set up some blocks, get a bottle jack, and try to jack up your garage.
Re: Gear legs
Postby radfordc » Sat May 16, 2015 4:58 pm
I bent a leg and was fortunate to have a friend who worked where there was a 50 ton press. He said that it was scary how much force it took to get it straight again.
Re: Gear legs
Postby DCASonex » Sun May 17, 2015 10:41 am
radfordc wrote:I bent a leg and was fortunate to have a friend who worked where there was a 50 ton press. He said that it was scary how much force it took to get it straight again.
Scary is right. it takes a lot of reverse bend to get titanium straight again and that is a lot of stored potential energy just waiting to explode if the bar happens to twist a bit under pressure and invert 180 degrees. Use Care.
Re: Gear legs
Postby JerryCPP » Sun May 17, 2015 11:54 am
I bent my 8 ton HF press trying to straighten mine. I then used a 12 ton and it worked, but just barely. Sonex N1320X.
JerryCPP
Re: Gear legs
Postby Bryan Cotton » Sun May 17, 2015 2:16 pm
I think we can forget my jack up the house idea!
Re: Gear legs
Postby rkurian » Mon May 18, 2015 1:48 pm
Thanks all for the ideas, I'll try to find a machine shop or something to give me a hand with this. I've ordered another leg "just in case"
Ray
Ray Kurian
Sonex 612 (N115DM)
Plans Built
rkurian
Users browsing this forum: No registered users and 83 guests
