Sonex spinner ?
Sonex spinner ?
Postby Sonex541 » Thu Apr 23, 2015 7:44 am
Well I finally got around to install my new prince prop. The problem is the bore in the front of the prop is a lot bigger in diameter than the Sonex spinner. I don't know if someone before me machined down the spinner to fit the smaller diameter sterba prop or what happened. The diameter on my Sonex spinner is only about 1/2 inch were the prince prop bore hole is about 1 inch. Not sure what to do. The bore on the back fits the prop hub perfect .can someone tell me the diameter of the Sonex spinner. To see if mine has been turned down. Thanks adam
Sonex541
Re: Sonex spinner ?
Postby sonex892 » Thu Apr 23, 2015 5:40 pm
On the spinner tor the 3300 jabiru its 1"
sonex892
Re: Sonex spinner ?
Postby Sonex541 » Thu Apr 23, 2015 6:06 pm
I have the revmaster. But yes I figured it was machined down to fit the sterba prop , not sure if I need to buy a new one. But more than likely
Sonex541
Re: Sonex spinner ?
Postby fastj22 » Thu Apr 23, 2015 7:35 pm
I have a Jab3300 spinner that fit my Prince I just replaced with a Van's one. PM me if you want to deal.
Re: Sonex spinner ?
Postby Rynoth » Fri Apr 24, 2015 8:42 am
I just checked my spinner (included in the Sonex kit for Aerovee) and the "pin" at the rear is exactly 3/4".
Re: Sonex spinner ?
Postby radfordc » Fri Apr 24, 2015 9:47 am
Does the "pin" on the spinner serve a purpose? Seems if the bolts are all secure the pin isn't needed.
Re: Sonex spinner ?
Postby Sonex541 » Fri Apr 24, 2015 5:58 pm
Well after further investigating my old prop there was a bushing that I popped out and installed on the spinner and it fit perfect into the new prince prop , has anyone else. Had to install a bushing between there spinner and prop , never seen or heard of it before but hey it works
Adam Simmons
Sonex
541
Sonex541
