Question for the scratch builders
Postby Concorde » Sat Apr 04, 2015 10:50 am
What is a good place to buy a small quantity of Aluminum ?
Are all 6061-T6 the same no matter who sells them ?
When you cut a piece like a splice plate , does it matter to go with grain or against ?
Yesterday I bent my splice plate the wrong way (SNX -F26-06) and for this one I will order it from Sonex, but I was thinking about keeping a few pieces of aluminum like in this case 3/16 6061 - T6 plate on hand for all future screw ups .
Thanks in advance.
Ben
Ben
Sonex # 1684
Tri-Gear, Dual Control
Rotax 912uls
N379BS reserved.
Concorde
Re: Question for the scratch builders
Postby Bruce593SX » Sat Apr 04, 2015 10:58 am
I bought the full sheets and sticks from a local metal supplier... Some of the thicker stuff that I didn't need big pieces of I got from Spruce.... HINT: Get the pilot card visa from spruce and you get free ground shipping over $100.(has size restrictions). Has saved me a fortune as I get close to finishing.
I didn't pay any attention to grain.
Bruce Johnson
Sonex 593 AeroVee Turbo
Bruce593SX
Postby Bryan Cotton » Sat Apr 04, 2015 11:01 am
Ben,
Always check your local suppliers. Many of them won't sell small pieces though so I end up at AC Spruce or similar for the "oops" pieces. My experience from a local supplier is the price drops rapidly as the number of sheets go up. When I bought extrusions for my hummelbird I bought double because they were so cheap.
Aluminum 6061-T6 is the same anywhere. If buying a quantity from a local supplier ask for mill certs (paperwork which says the tested material properties of the batch) but don't tell them you are building an airplane.
Bend across the grain if you can. For slight bends like a splice plate I would not worry about it. Also for a generous radius, like a splice plate you will be fine. As long as you adhere to making the bend radius 4X the thickness you should be able to bend with the grain, especially 6061. Finish your edges before you bend!
Check out ebay for small pieces too.
Postby NWade » Sat Apr 04, 2015 12:39 pm
As Bryan mentioned, you always want to plan your pieces so that you can bend parts perpendicular to the grain, whenever possible. This and other important building information can be found in places like AC-43.13 and books like "Kit Airplane Construction" by Ron Wanttaja
(which I highly recommend reading. Its on Amazon.com here: http://www.amazon.com/Kit-Airplane-Cons ... n+wanttaja )
Another alternative is to go attend an EAA SportAir workshop. Their basic class on Sheetmetal aircraft is super-valuable, and they hold the classes all over the US throughout the year.
As for metal sources, I found http://www.onlinemetals.com to be a good supplier for sheets, angles, and channel-stock.
Good luck in your build!
--Noel
P.S. Be careful buying pieces from eBay and other secondary sources. You can get great deals sometimes; but you need to make sure the factory printing on the metal is still visible, identifying it as 6061-T6 (and check it thoroughly for any signs of corrosion, of course)
Postby Bryan Cotton » Sat Apr 04, 2015 1:27 pm
I agree with Noel's PS on ebay. You won't get certs but if the printing is on there I would be comfortable.
Postby MichaelFarley56 » Sat Apr 04, 2015 3:53 pm
Just as an FYI, I've had no luck finding local sources for 6061-T6 around me but I did find that www.speedymetals.com has a lot of 6061-T6 available in different sizes. I've made several orders there and never had an issue.
Postby rizzz » Sat Apr 04, 2015 5:42 pm
I thought these guys were pretty good:
https://www.shapirosupply.com/
I bought my all aluminium angle from them.
It turned out cheaper to buy the angle from them and get it shipped to Australia than buy from our one and only supplier we have here in the land down under (airportmetals).
Postby Concorde » Sat Apr 04, 2015 6:20 pm
Thank you all very much for all your great suggestions.
Ben
Ben
Sonex # 1684
Rotax 912uls
N379BS reserved.
Concorde
Postby Gripdana » Sun Apr 05, 2015 9:01 am
I thought of one more thing. When I started buying metal I was given some angle that was not 6061. I purchased 6061 but I was given the wrong material. I bought it from a very large supplier here in Los Angeles. I posted a photo and someone warned me to check it out. The part was the angle that mounts the vertical stabilizer to the tail. Kind of important to have the right material. I was told and researched the fact that 6061 angle has a radius on the inside of the angle (acts like a gusset) and on the edges. There are NO "squared" or 90 degree edges except for the outside of the 90 degree angle.
Dana Baker
Scratch Built
First Flight March 8, 2015
Gripdana
Users browsing this forum: No registered users and 72 guests
