by MichaelFarley56 » Sun Dec 07, 2014 1:56 pm
My biggest fear would be the amperage draw of the seats. Any idea what the power draw is? Most alternators recommend a max continuous draw of 80% which for us means you only want to pull 16 amps out of the AeroVee.
If the airplane is using at least a few amps to run systems, that doesn't leave a whole lot of power to run seat heaters.
Just as a thought...have you looked into battery powered heated seats, gloves, socks, etc? I'm sure the cost will go up, but that may be an easy answer to give you some needed heat without running into power draw problems.
Either way, let us know how things go! I'm sure a lot of people will be interested in your solution.
