by grevaly » Sat Oct 18, 2014 11:51 am
Hello, I am ready to do the cowling on #1242 and am building an areovee 2.0 that I purchased second owner. The kit
was still unassembled an in original packing. the assembly has been going well icluding the dreaded prop hub. Crankcase
closed, I took the piston set out of the box and discovered that one piston assy was missing the wrist pin! It was a why do these
things always happen to me moment. Since I knew sonex would probably not help since I was second generation owner, I
talked to MAHLE and MAHLE aftermarket and for some reason they could not recognize the #'s off the data tag on the mahle
box so they cold not identify the part I required. I have searched around and called a few places and was having no luck.
I called Kerry and told him my problem and graciously went and scrounged around but was not able to dig up a single pin.
I would have to by a complete piston jug assy.
I am wondering if anyone might have spare wrist pin from switching cylinders or a rebuid or may have an idea where
to go to get one. The pin is .888 dia and 2.930 length mahle. Thanks.
Mark
Mark Conner
Sonex Std Gear Aerovee #1242
Mostly Plans Built
