Bryan Cotton wrote:I have started to look ahead to the gear mounting. Boy do I wish that I drilled the tail spring and bracket together before I assembled and riveted in the tailpost!
Any hints?
If you've been following the plans without question, you already have the 1/4" hole in the bracket, so the challenge becomes drilling a matching hole in the titanium tail spring. What Scott suggested is probably the best method... insert the tail spring, mark the hole locations, and do your best to drill/ream out a hole that matches.
Then the trick becomes drilling the tailwheel pivot fitting (if you have the older style welded components) in a manner that is as close to perpendicular as possible (so that the tailwheel itself is vertical)... I messed that part up by a good 10-15 degrees and am waiting for a replacement pivot fitting to try it again.
