avee8r wrote:to save the weight, complexity, and hindrance of the screw and spacer etc... I simply move the flaps out of the fully retracted position, then pull the parking brake handle back and put it into the "0 degree" flap slot.
John
N50NX
avee8r wrote:Maybe someone has already posted this but to save the weight, complexity, and hindrance of the screw and spacer etc... I simply move the flaps out of the fully retracted position, then pull the parking brake handle back and put it into the "0 degree" flap slot. Works like a charm, no added weight or complexity, and will hold the plane to 2300 rpm if the cable is adjusted properly.
Happy Landings
John
N50NX
Users browsing this forum: LLR and 80 guests
