fastj22 wrote:So your nose bowl hangs off the baffle fence which is attached to the engine somehow? I checked out your Expercraft site and it didn't grab me quite how it hangs. Very interested though. I like the look.
In many ways it fits like the universal cowling in that it is attached to the air frame at the firewall across the top (windshield strap) with screws & nuts, and then down both sides and underneath with piano hinge. Once the top (excluding the doors), both sides, and the bottom are all connected to the nose bowl it becomes ridged as if it were a single piece. Nut plates are used to attach the top, sides, and bottom to the nose bowl.
Southcos are used on the doors. My Southcos work pretty well and make preflight easier. The sides and bottom are fairly easy to remove but taking the nose bowl off can be a bit of work. That is rarely ever needed unless I need to adjust/change the alternator (dynamo) belt.
Dale Williams
N319WF @ 6J2
Myunn - "daughter of Cleanex"
120 HP - 3.0 Corvair
Tail Wheel - Center Stick
66.0 hours / Status - Flying
http://kitplanes2.com/blog/2013/12/ownerbuilder-2/http://www.youtube.com/channel/UC49h6Qijc17_Ebfz0CbRFtg
