Fuel Vent Issue
Posted: Sun Jun 15, 2014 10:23 pm
Hi Folks
It seems that I have a Fuel Vent issue. I was running some static RPM tests today and it was the first time that the engine has run for more than 10 minutes at a time since being installed on the airframe
The engine ran fine for the first few minutes and after that it would start and then just die a few seconds later. After playing with Carb/Mixture settings for a couple of hours and beating my head against the wall to no avail, I decided to see if it was a fuel vent issue. I loosened the fuel tank cap enough so that some air would get into the tank and tried again.
Guess what .... the engine starting running perfectly. I ran it for a long time after that without any glitches
To validate the theory, I closed the fuel tank cap tight again and the same problem popped up again. I am using a 90 deg elbow in the tank air vent hole and have a 3/16 metal brake line running down along the firewall and venting at the bottom. It is venting straight down so I am not sure if that is the issue vs having it bent forward to have some positive air pressure. I did blow air through the vent line and it does get through but requires quite a bit of pressure with the fuel tank cap closed. I don't think there is a block in the line either
Has anyone else experienced similar issues. If so how did you solve it?. I was considering using a bigger vent line but not sure if that is the right solution. I would welcome any thoughts and suggestions including ideas for venting
Best Regards
Best Regards
