by n502pd » Mon Jun 16, 2014 8:59 pm
When I did my vent line reecently, I looked at the size of specified tubing. I thought it might be a bit small, so I used 3/8 diameter, and hope I dont have any problems like yours. Remember the vent line takes air into the tank as fuel is removed by the engine, and there should be no pressure difference fro outsid air to inside tank air (or very very little difference). If there is any measurable difference then you are actually pulling a vacume on the tank, and less fuel will flow out to the engine. At least that is how I view this process. I have also beveled the bottom end and bent forward a slight bit to have a bit of ram air effect, and be sure it is below the bottom edge of the coweling and in the slipstream. :)
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
