by Darick » Tue Sep 23, 2014 9:38 pm
While not an assembly manual question, this is an assembly order question. The Sonex instruction sheet on skinning the wing says to attach the top skin, flip over, then the bottom skin, flip over again and attach the top leading edge, flip over again pull the leading edge down and fasten it.
I've got the top skin drilled and the bottom skin drilled, and wondering if there is a good reason to start with the top leading edge which means I have it flip it again. Id rather just leave the wing in its present position, that is bottom side up, and put the bottom leading edge on first. I'm having a difficult time flipping the wing especially as it getting heavier all the time. Is there a good reason not to do this?
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
