Control Stick is loose
Re: Control Stick is loose
Postby Sonex1517 » Wed Mar 28, 2018 7:16 pm
racaldwell wrote:For a new installation on my mixer, I am going to use #1 taper pins. What length is needed?
I am not near the parts until the end of the week or I would measure them.
TIA,
Rick
Xenos 0057
Rick - see if this helps. Eric Seber wrote it up. I used taper pins in my Sonex and have been happy with the results.
http://www.sonexfoundation.com/uploads/ ... lation.pdf
Somewhere out in Sonexland is the reamer available for loan....
Postby Bryan Cotton » Wed Mar 28, 2018 7:36 pm
Last I saw, Bill Volcko had it.
/viewtopic.php?f=34&t=3359
Postby bvolcko38 » Thu Mar 29, 2018 10:56 am
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Postby racaldwell » Mon Apr 02, 2018 10:04 am
I started to ruin my tailspring mount yesterday installing a #2 taper pin. This is to replace the AN4 bolt the plans call out. I was reaming the hole with a #1 taper pin reamer by hand. I noticed even with the mount in a vice that my hand twisting movement allowed the reamer to take more material from the steel tube than the titanium rod. I was wallowing out the top hole in the tube and soon would have created another part for my scrap pile. I stopped and jigged the tailspring mount in my mini-mill. This worked great by keeping down pressure on the reamer while turning with no unintentional side movement. Results were great Here are a couple of pictures.
Rick
Xenos 0057
Tailspring taper pin completed
Trial fit of the #2 taper pin in reamed hole.
racaldwell
Postby pgerhardt » Wed Jun 06, 2018 8:08 pm
When the taper pin is fitted correctly, I cut off the excess with a Dremel tool and cut off wheel.
pgerhardt
Postby Wood » Fri Aug 04, 2023 7:58 pm
Sonex1517 wrote:Eric Seber documented this process here:
http://www.sonexfoundation.com/uploads/Seber_Taper_Pin_Installation.pdf
Somewhere in the community is a taper pin reamer available as a loaner - last I knew it was in the hands of Bryan Cotton, but I think he loaned it to someone.
Does anyone have the new link to this document or the PDF they can post. Keep getting document can’t be found.
Lyncrest Airport - CJL5
Winnipeg, Manitoba
Sonex Legacy #0327
Jabiru 2200
Serial # 22A 1130
AeroConversions
Wood
Postby gammaxy » Sun Aug 06, 2023 1:31 am
I found a copy on the "Wayback Machine" at:
https://web.archive.org/web/20200110043 ... lation.pdf
Postby Wood » Sun Aug 06, 2023 9:19 am
Thanks for this. Appreciate you taking the time.
Mark
Winnipeg, Manitoba
Sonex Legacy #0327
Jabiru 2200
Serial # 22A 1130
AeroConversions
Wood
