8pointroll wrote:Just finished test fitting my wings--used WD-40 but it was a nightmare and a half getting the wings in and not so bad removing them--what do you guys recommend to make it easier? In the absence of a better suggestion, I'm thinking a liberal dose of anti-seize lube on all contact surfaces instead of WD-40 which will also make it easier to remove the wings than WD-40 which will lose its effectiveness over time.
For those of you who have used the Vans wing root gap seal, I have the following questions:
1. What was the gap you used between the wing skin and the fuselage?
2. I noticed that the seal flap under the wing skin separates from the wing skin when you raise the sealing flap into a nice radius--did you use any sealant to hold the gap seal to the underside of the wing skin? If so, what did you use?
Any lessons learned, things you would do differently, tips of things I should do or not do?
Thanks in advance for your input.
