kmacht wrote:The cheapest non 110v option at Spruce is the red dragon at almost $500. There has to be something out there less expensive.
radfordc wrote:One winter day I used a length of dryer hose connected to the exhaust pipe of my truck to warm the engine. This worked...sorta. Along with the warm exhaust there is a lot of water vapor, so the engine compartment was dripping water after a half hour. Didn't seem to cause any problem as the engine started up and ran OK.
MichaelFarley56 wrote:Great question Mike. I'm certainly no expert on fluid dynamics, but from what I've read, the main goal is to have the oil warm enough that it can easiliy flow through the narrow oil passages, thus allowing for good bearing lubrication as soon as you fire up the engine. For us this may also help prevent a pressure overboost when we start a cold engine with cold, thick oil in the sump.
In most cases, having the oil up to 100 degrees is certainly sufficient so if it were me, I think that would be my goal. I'd try to determine what heat is needed so that the oil could slowly be warmed up to around 100-120 degrees after several hours. Oil viscosity is quite different at 100 as compared to freeing temps!
mike.smith wrote:The oil is what I used to think, until I read this, which makes all the sense in the world to me:
http://www.avweb.com/news/maint/182846- ... directed=1
That's why I'm planning to add these heaters across the cylinders as well as under the oil sump.
I dropped Sonex an email this weekend to see if they had any insight.
Consider your steel crankshaft, which is suspended by thin bearing shells supported by a cast aluminum crankcase. As the engine gets colder, all of its parts shrink in size, but the aluminum case shrinks twice as much as the steel crankshaft running through it. The result is that the colder the temperature, the smaller the clearance between the bearing shells and the crankshaft. That clearance is where the oil goes to lubricate the bearings and prevent metal-to-metal contact. If there's not enough clearance, then there's no room for the oil, regardless how high the oil pressure gauge reads.
Users browsing this forum: No registered users and 84 guests
