Aerobrake puck and disc wear?
Re: Aerobrake puck and disc wear?
Postby Bryan Cotton » Sat Oct 21, 2023 10:26 am
My brakes hold at WOT, probably an Aerovee benefit.
Postby 13brv3 » Sat Oct 21, 2023 2:02 pm
Bryan Cotton wrote:My brakes hold at WOT, probably an Aerovee benefit.
LOL!
Rusty
Fixed wing, gyroplane, A&P
13brv3
Postby Kai » Sun Oct 22, 2023 10:07 am
Probably…………
Sonex A #0525- SG, DS.
Kai
Postby 13brv3 » Tue Oct 24, 2023 3:54 pm
I got a reply from Sonex about the brake puck material. The good news is that they're using that same material I linked from McMaster-Carr. The bad news is that they're already using the high-friction version, so there won't be any room for improvement from those materials. It's good to have the coefficient of friction number though, since I can compare that to other materials I might find.
Rusty
13brv3
Postby flyguy0609 » Tue Oct 24, 2023 6:16 pm
Rusty,
" I wonder how long an end mill would last cutting brake lining material :-)". I love my end mil, but not enough to give her a name. :-)
Harvey Tool has end mills for everything. I would suggest you look at their end mills for composites.
https://www.harveytool.com/products/mat ... ng%20tools
hope this helps
flyguy0609
Postby 13brv3 » Tue Oct 24, 2023 7:22 pm
I was mostly joking about the end mill. I'd just sacrifice cheap ones if I manage to find a suitable material.
The question now is whether we can find suitable friction material. It would need to be at least 5/8" thick, and the diameter of the pucks is 1-1/8". The stock material is listed as 0.55 max coefficient of friction, max temp 550F, and max pressure of 500 psi.
Rusty
13brv3
Postby mike.smith » Fri Nov 03, 2023 8:44 pm
I have a couple if thick washers between the brake body and the wheel/bearing. Otherwise the brake pad and puck are in constant hard contact with one another. I have had my current pucks for 3 years and they are still in good shape, without need of replacement.
