Tail tips tips
Re: Tail tips tips
Postby Bryan Cotton » Thu Dec 19, 2013 1:21 am
Here is a view of the Waiex tip in place. Easy to transfer holes when they are on top!
Re: Tail tips tips
Postby Bryan Cotton » Thu Dec 19, 2013 9:01 am
I did notice that the trailing edge of the tip sticks past the ruddervator. I think I will trim the edge that goes against the rib. Because of the sweep of the leading edge that will move the tip forward.
Re: Tail tips tips
Postby Rynoth » Sun Dec 22, 2013 12:11 pm
Bryan, looks good! I did mine awhile ago, and trimmed off that little 1/4" strip that sticks out aft of the skin. I finished my ruddervators last night and upon installation realized that the little strip is actually to fill the small gap outboard of the end of the piano hinge. Oops. Aesthetic detail that makes it all my own!
Re: Tail tips tips
Postby Bryan Cotton » Sun Dec 22, 2013 7:59 pm
Ryan (or anybody),
I could trim the 1/4" off the back, or I can make the tip shorter, i.e. less span. That will pull the trailing edge in because of the taper of the leading edge. Anybody have thoughts on which way is better? The only downside of trimming like you did is you have to glue it back together. The downside of my proposed method is a lot more cutting.
Re: Tail tips tips
Postby Bryan Cotton » Mon Dec 23, 2013 12:28 am
So much for paralysis by analysis - I figured out the tips need to be 11/16" shorter to make up the 1/4" in the trailing edge. I marked it up and cut it out. Pictures show the shortness and change in length.
One short and one out if the box tip
Need to retrim the cutout for the ruddervator. Noses are even, TE about 1/4" shorter.
Re: Tail tips tips
Postby Darick » Tue Feb 25, 2014 10:38 pm
On a related matter, does the fiberglass tend to crack at the rivets due to the small localized stress due the rivet? Has anyone used something like a washer to spread out the pressure of the rivets on the tip rib?
Darick
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Re: Tail tips tips
Postby Bryan Cotton » Tue Feb 25, 2014 10:47 pm
Darick,
I have seen a lot of glass riveted to sheetmetal and no worries about cracking.
Re: Tail tips tips
Postby Darick » Tue Feb 25, 2014 11:01 pm
Ok. Thanks.
Darick Gundy
Sonex #1646
N417DG
Darick
Re: Tail tips tips
Postby Rynoth » Tue Feb 25, 2014 11:24 pm
Darick wrote:On a related matter, does the fiberglass tend to crack at the rivets due to the small localized stress due the rivet? Has anyone used something like a washer to spread out the pressure of the rivets on the tip rib?
Darick
Without directly answering your question, I wanted to pass on some fiberglass riveting information I received from Kerry at Sonex.
Me: "The plans call for normal CCP-42 rivets to attach fiberglass wingtips, I'm worried that this might be too much concentrated pressure on the fiberglass holes on the shop end of the rivet, any issues/suggestions for this?"
Kerry: "You can use aluminum rivets on the wingtips, as they are non-structural, but not on the tail tips. "
Me: "Any issues/concerns on using small aluminum washers under the rivet heads when the fiberglass is the outer layer? "
Kerry: "No washers are needed under any rivets for the fiberglass. The parts can be installed as shown in the plans."
Me: "Is there a particular type or brand of fiberglass filler you recommend to use with the fiberglass in the kits?"
Kerry: "Any off-the-shelf fiberglass repair kit can be used on our fiberglass parts."
I'd like to note in this that the only concession he made versus the plans is using aluminum rivets on the main wing tips (aluminum rivets being weaker and subjecting the fiberglass to less pressure, if you're worried about that sort of thing.) The tail tips, on the other hand, are structural and subjected to airflow and need to have the normal ccp-42 rivets as called for in the plans.
Re: Tail tips tips
Postby Bryan Cotton » Tue Feb 25, 2014 11:34 pm
I have set solid rivets in fiberglass too. I think this is harder on it than pops. I did my buddy's RV7 wingtips when I was stuck in Florida once.
Users browsing this forum: No registered users and 77 guests
