Should change the topic, but Re- Tracy Obrien axles and fitting Azuza drum brakes...
Rather than cut anything off the axle assembly I made an aluminum spacer about 3/8" thick to mount the drum brake backing plate.
A little was skimmed off the spacer to make sure the brake drum assembly had the right position over the brake shoes.
Backing plate and spacer is bolted up to the axle with the 4 bolts. Brake plate is drilled and tapped for the wheelpants.
This way if I ever decide to upgrade to the discs, they will go straight on.
Cheers
Tony
(Sorry about the picture size..)
Spacer
This fitting holds the wheelpant on, a 10/32 thread for the screw. The fitting is held in by the axle split pin. No probs after 113 hrs.
