radfordc wrote:pchuckie wrote:How would one go about buying this partially built kit, finish it and register it themselves being the builder?
If you buy the project, and if the previous builder has documentation for the work he did, you can finish the build and register the plane as an experimental. There can be more than one "builder"....in fact there isn't a limit as to the number of builders as long as they do it for "education and recreation". In other words you can't pay someone to build it for you.
In order to get the repairman's certificate, you are supposed to be the "primary" builder. http://www.flightsimaviation.com/data/F ... 5-104.html
There isn't a definition for what constitutes "primary". I've read that if you are the person who signs off in the logbook that the plane is airworthy and ready for inspection, that can make you the primary. You do have to convince the FAA that you are capable of performing as the repairman. There was a group of guys in Oregon who bought 13 kits and worked together as a committee to build them. At the end they drew lots to see which airplane they got. No one person did the majority of work on any one airplane but they still were the primary builder for the plane they got.
Bryan Cotton wrote:I thought that with a A&P you could do a condition inspection on experimentals. Less stringent than the certified world where you need your IA to do an annual. I had a lot of co-workers who got their A&P after military service working on aircraft. It is a good thing to do.
fastj22 wrote:The only benefit the repairmans certificate buys you is the ability to sign off your own condition inspections. Any A£P can also sign them off and probably won't charge you an arm and leg if you assist him. And another set of eyes certainly isn't money thrown away.
Users browsing this forum: No registered users and 62 guests
