Full Swivel Tailwheel
Re: Full Swivel Tailwheel
Postby mike.smith » Sat Feb 21, 2015 7:30 pm
I just look at my tailwheel Sonex as handling like a tricycle gear aircraft, in which I've flow most of my hours. In fact it turns tighter than the Warriors I've flown for many years. I have a runway that is not aligned with the prevailing winds. It's tricky enough in a crosswind with the standard Sonex tailwheel. I don't need the added excitement of a castering tailwheel :-) .
Postby fastj22 » Sat Feb 21, 2015 7:38 pm
Fastcapy wrote:Like Fastjj said, most taildraggers have the swivel setup.
I also would buy one if it could handle the Matco 6" pnumatic tailwheel I just installed. I love that little wheel.
From the website, looks like they don't stock them and probably build to order. I bet we could ask for a bigger fork for our wheels.
Postby fastj22 » Sat Feb 21, 2015 7:43 pm
mike.smith wrote:I just look at my tailwheel Sonex as handling like a tricycle gear aircraft, in which I've flow most of my hours. In fact it turns tighter than the Warriors I've flown for many years. I have a runway that is not aligned with the prevailing winds. It's tricky enough in a crosswind with the standard Sonex tailwheel. I don't need the added excitement of a castering tailwheel :-) .
I understand, but you really shouldn't be relying on your tailwheel to keep you on the runway. Fly the tail, my instructor say. But I have relied on that direct steer wheel to keep me from skidding to the side a few times. The big 6 inch Vans wheel I have really helps.
On a trike note, my initial instruction was done in a Diamond DA20. Castering nose gear, steer only by brakes until the tail works. My C150, was much like a tri-Sonex.
Postby Fastcapy » Sat Feb 21, 2015 11:20 pm
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby mkellems » Sat Feb 21, 2015 11:38 pm
Flyboy Accessories has a neat lightweight 4" full swivel tailwheel and Aviation Products has had them for years.
Both perform great with the Sonex/Vans rod type tailspring and indvidual braking.
I have the AP version on my Sonex with hyd toe brakes and it works like any other tailwheel aircraft I have ever flown. Turns on a dime as well as hand free, effective braking at the landing/taxi speeds of the Sonex.
Just my 2 cents.
Thanks,Mike
Tough Times Don't Last Tough People Do!!
mkellems
Postby vfrazier » Sun Feb 22, 2015 12:31 am
Hi guys. I'm Vince Frazier. I make the full swiveling, STEERABLE tailwheel fork mentioned above.
The reason that I sat down, created an account, and am replying to this thread, that was shared with me by a Onex builder, is that there are a LOT of misconceptions talked about in the comments above. Please let me clarify exactly what our tailwheel will do.
A local Onex builder, Todd Reifers, asked me if I could make a smaller, lighter version of our Screaming Eagle full swiveling, STEERABLE tailwheel fork that can be found on hundreds of Van's RVs. I told him that I could and asked him for various dimensions, AND we discussed ways to add differential braking. Todd took care of the differential braking with a very simple, very clever heel brake installation that uses the stock cable brakes. I produced the smaller tailwheel, which is designed to use a 4" DJM lightweight solid rubber tire. Together, they make a nice upgrade to the Sonex/Onex steering and ground handling.
Now let me explain how the tailwheel works, because what is indicated in the comments above are somewhat misleading. First off, it absolutely has positive steering and only unlocks when rudder input is hard over to the left or right, AND when the tailwheel tire has force against it, such as when turning into a parking space. It is very unlikely to come unlocked on the runway since the tailwheel tire should be mostly in trail. It is very unlikely to come unlocked at any time without the side force typically seen only at slow, tight turning speeds and with simultaneous full rudder input too.
So, no ground loops due to tailwheel design! Sorry, ground loops are still due to pilot error, stuck brake, too much wind, poor main gear alignment, etc.... but I can't help but point out that the stock Sonex brake design certainly doesn't give you the extra anti-groundloop benefit of differential braking! Having said that, there is nothing wrong with the stock set up. But it doesn't turn very tight, does it?
How does our tailwheel steer and swivel and stay locked and come unlocked at the appropriate times you ask? Inside the body of the tailwheel mount housing are a locking pin, spring, and a cam type groove. The locking pin positively engages the control arm. The control arm engages the rudder horn via a push rod AND simultaneously engages the tailwheel fork for positive steering. And the rudder is controlled by your rudder pedals, of course.
Under normal, straight-ahead, conditions, you can't disengage the steering unless you shear the pin!! So, yes, this system is every bit as positive steering as the stock Sonex non-swiveling tailwheel.
So, when does it unlock and swivel you ask? Well, only when it's supposed to, unless something is worn, broken, etc. When is it supposed to unlock you ask? Only when: 1) you have slowed down to a slow taxi speed, such as when parking, and step on full rudder, or 2) when you're pushing the aircraft backwards and the tailwheel fork swivels past the lock limits and the pin disengages.
Take a look at the photo on this page: http://www.flyboyaccessories.com/Tailwh ... p/1109.htm
It doesn't show the control arm, or the steering rod, etc. but it's the only photo I have online. Nonetheless, it should help clarify the operation of the unit.
In the past several months, we have built a few units for other Sonex/Onex builders too. Todd says he is very pleased with his new tailwheel and brakes. I don't know if Todd Riefers is on this forum, or if he is available through any of the Sonex/Onex contacts or builder's lists. I would hope that others can contact him directly for his input.
We also make several other tailwheels, mostly for the RV guys, with various tire diameters up to 7.5" Any of the RV tailwheels could be adapted to the 0.635" OD Sonex spring (stinger). However, the RV mounting angle is slightly different, so the pivot wouldn't be vertical unless the spring (stinger) were intentionally bent. It's easier to simply use a mounting socket specific to the Sonex/Onex. We make those too, of course.
Hope this clarifies the way the tailwheel works. For more info please contact me directly at vincefrazier@gmail.com I'm not routinely on this forum, so please email instead of sending a PM.
vfrazier
Postby fastj22 » Sun Feb 22, 2015 12:53 am
For those of us who installed diff braking, looks like this could be a real nice upgrade.
Postby mike.smith » Sun Feb 22, 2015 1:42 am
Fastcapy wrote:Mike, I am curious as to what did you do your tailwheel training in?
Cub, Citabria and Super Decathalon. I fly aerobatics in the Super D. I know how to fly a tailwheel. The Sonex has direct steering. I like it. I don't want to change it. If you let the tail go it will skid, yes, but you have to try hard to actually ground loop it. When doing wheel landings you fly the rudder like any other tail dragger. When I take off in the Sonex, 100% of the time I lift the tail up and take off from 2-point. I feel I have more control. In 3-point, as I was trained at Sonex, I find it too easy to skid the wheel around, especially in a cross wind. I like flying "real" tail draggers. But I also really like flying my direct steering Sonex. I wouldn't change it if you paid me. :)
Postby Fastcapy » Sun Feb 22, 2015 2:15 am
Mike Beck
Oshkosh, WI (KOSH)
Sonex #1145 N920MB
Fastcapy
Postby fastj22 » Sun Feb 22, 2015 10:34 am
This product does look like the best of both worlds. Superior to the typical spring loaded detent of the other tail draggers. I'll be contacting them to see if they can build me one to handle the 5.5" vans wheel I currently have then work on the spousal justification.
Users browsing this forum: flyguy0609 and 4 guests
