Rolls, Loops and Spins!
Re: Rolls, Loops and Spins!
Postby mike.smith » Tue Sep 30, 2014 7:02 pm
Sonex825 wrote:I always heard we were discouraged from spinning the Sonex intentionally
Eric M
I've never heard that! The Sonex spins nicely. Very predictable. I did spins and spin recoveries multiple times before trying anything else, like aileron rolls and loops.
Postby Pickleman » Wed Oct 01, 2014 2:17 pm
The Sonex flight manual clearly states that in bold type that " Intentional spins in the Utility Category are prohibited." Anything over the 850 lb Areobatic Category max weight would be in the Utility Category. Given a 620 lb airplane, 180 pilot, and half fuel, all you FAA pilot builds can spin till you puke! Lol
Pickleman
Postby gammaxy » Wed Oct 01, 2014 2:46 pm
The aerobatic max weight is 950 lbs. No problem for my 650lb airplane, 200lb self, and full fuel. I would double check the balance first to be sure though.
Postby Sonex825 » Thu Oct 02, 2014 12:40 am
Good to know! Not saying I never did one but always thought I wasn't supposed to. I was out doing some mild aerobatics this evening. I think split s's have got to be one of my favorite things now but I always loved spins too. I am going to have to start reintroducing them to my joy flights.
Eric M
Sonex825
Postby Pickleman » Thu Oct 02, 2014 12:47 pm
Mr. Gammaxy, you are correct about the updated aerobatic weight. I was reading from my flight manual-an older one--and it stated the 850 lbs I quoted. The website now clearly states 950lbs. Was that just a numbers change or did that reflect any structure change? With 950 lbs, even some big boys can get busy inverted!
I need to get caught up on what has changed now that I am getting close! I bought plans #116 bout 14 years ago, and have scratch built all of it--even sawing the old spar cap blanks into shape. Work, other planes, family,mand illnesses all took time away from the Sonex, but she is close now!
Pickleman
Postby sonex1284 » Sat Oct 04, 2014 1:50 pm
That is a good point. Of course you should be flying solo. My plane is just at 700, I'm 180 lbs and I fly with about half fuel. (but I probably have 2-3 pounds of GoPros mounted!)
Mike Kelley
The Villages, FL 32163
Sonex 1284, N154MK, Tri-Gear w/Jab 3300
sonex1284
Postby fastj22 » Sun Oct 05, 2014 9:38 pm
For those wondering if a Waiex recovers from a spin, take a look. Note, I'm solo and am wearing a parachute.
http://youtu.be/xP4EAMk-ZAU
Postby Jstovall » Thu Oct 30, 2014 6:24 am
Speaking of parachutes, anyone recommend a certain type of parachute for the Sonex. I am in the market.
Jstovall
Postby SonexN76ET » Thu Oct 30, 2014 11:54 am
Speaking of parachutes, I have a Softe Wedge parachute. This one is strapped on your back, so you still need a cushion for the seat bottom. It weighs 15 pounds and is comfortable to wear. Parachutes need to be repacked every 180 days at a cost of around $60 by an FAA certified and qualified parachute rigger. I have also tried a Long Softe which you sit on. It worked well too, but I think the Wedge Softe is more comfortable.
Sarasota, Florida
SonexN76ET
Postby fastj22 » Thu Oct 30, 2014 9:01 pm
Mine is a National Flat pack. 2 inches all around the back. If you have short legs, the wedge might work fine for you. Pushes my butt too far forward.
Users browsing this forum: No registered users and 84 guests
