vicdelgado9 wrote:Seeking clarification on purchasing an experimental project already built. I was under the impression, that even if someone else built it, and you finish it out (or it is already completed), it is still an experimental aircraft which means you can perform maintainence and repairs on it, you just cannot perform the condition inspection on it. Only the person that holds the repairmans certificate or an A&P can perform the condition inspection. Correct me if I am wrong on that please.
fastj22 wrote:vicdelgado9 wrote:Seeking clarification on purchasing an experimental project already built. I was under the impression, that even if someone else built it, and you finish it out (or it is already completed), it is still an experimental aircraft which means you can perform maintainence and repairs on it, you just cannot perform the condition inspection on it. Only the person that holds the repairmans certificate or an A&P can perform the condition inspection. Correct me if I am wrong on that please.
That is correct. The only thing the repairmans certificate buys you is free conditional inspections.
Users browsing this forum: Google [Bot] and 78 guests
