Airworthiness inspection questions
Re: Airworthiness inspection questions
Postby builderflyer » Sat Oct 15, 2022 9:52 am
pfhoeycfi wrote:
At some point I need to get the aircraft to a shop for the transponder test but I'm under the Philly Mode C Veil. I'm not sure how to make that happen given I need to fly to a shop to get the transponder tested and I presumably cant fly until the transponder is tested (I'm assuming the test needs to be performed while the transponder is in the airplane). Do you have any suggestions or clarification for that catch 22?
Thank you,
Peter......as Bryan said, you may be able to find a shop to come to you to do the transponder certification. Here, in northern California we have a fellow who comes from a couple hundred miles away to do the certification on many aircraft along a route he travels periodically. So because of the volume of work he gets on his trip, he actually charges less than if we individually flew to his shop. Try calling shops around in your area...........
Art,,,,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,Jabiru 3300 #261
builderflyer
Postby pfhoeycfi » Fri Oct 21, 2022 2:19 pm
After uploading the required forms, I click save and next, or just save and get the message in red. I cannot get the green check mark to appear next to the "documents" field. I've tried deleting the forms and re-uploading. I've signed out and then back in. NG. Scroll down ...the forms are there. Any ideas?
peter
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Postby Bryan Cotton » Fri Oct 21, 2022 2:41 pm
Here is mine. I think the digital 8130-6 was auto-generated from one of the other pages, but I don't remember for sure.
Postby pfhoeycfi » Fri Oct 21, 2022 4:31 pm
Bryan Cotton wrote:Here is mine. I think the digital 8130-6 was auto-generated from one of the other pages, but I don't remember for sure.
Yeah I don't have that digital 8130-6 entry. Maybe that shows up after hitting submit. I went back to the beginning and did every step per the EAA guide. I can see the uploaded docs in the review section. I just don't have the green checkmark indicating I'm done with the upload doc section. Its prob ok. I'll submit.
Peter Hoey
pfhoeycfi
Postby Jerry09w » Fri Oct 21, 2022 9:35 pm
According to the regulation (FAR43 appendix F) the test can be done on the bench. You should be able to drive the transponder to a shop and have it inspected. If it is a new installation with a separate encoder you have to make sure the data transfers correctly from the encoder to the transponder. When I had a shop, I had a few customers who shipped their transponders in for the test.
Jerry09w
Users browsing this forum: No registered users and 45 guests
