I am having an real issue with the seat pan in my legacy tri-gear Waiex. Please see attached pictures.
The seat as torn around the elevator pushrod proactive cover.
An unused tab on the joystick yoke is contacting the underneath of the seat pan.
The pan is also contacting the bracing on the landing gear mounts.
I am wondering if this is a problem that others have encountered and if so what their solution was to fix the issue permanently.
I have considered several solutions:
1. Small doubler over the tear and ignore the other issues. (Not really satisfactory).
2. Install a more rigid pan doubler over the complete effected area. (Would add weight, make the already seat more so and probably not work that well).
3. Make a new seat and wait of it to happen again. (Not really satisfactory).
4. Repair whole of pan with a lighter doubler and raise pan at middle hinge to increase clearances.
5. Make new seat with previous option in design.
Anyway if anyone has been here please let me know what you did and how it worked out.
- Seat tear
- Yoke tab interferance
- Seat contacting landing gaer
