Tail spring mounting
Re: Tail spring mounting
Postby Bryan Cotton » Tue Apr 26, 2016 10:49 pm
Man, you guys are making me feel like I have done something, even beyond my recent 11.5 hours of deburring and messing with root ribs.
Postby Spaceman » Wed Sep 20, 2017 11:33 pm
Guys,
I'm getting ready to build my aft fuselage, but before I install the tail post I think I'll drill the tailwheel spring to the steel bracket while everything is accessible.
Are there any tricks to clamping the rod in the bracket so it won't move, and also ensuring I drill nice and perpendicular/centered through both parts?
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Postby kevinh » Wed Sep 20, 2017 11:57 pm
Spaceman wrote:Guys,
That's what I did and it seemed to work good. I drilled the tailwheel to the spring then I just used some scrap wood and clamps to jig the tailwheel/spring assembly to the metal weldment with the wheel straight and level.
kevinh
Postby Bryan Cotton » Thu Sep 21, 2017 7:10 am
I would drill one hole in the steel first. Then I would transfer that hole a little bit into the ti. Pull the rod out and drill that hole all the way through the ti using a V block and drill press. Then put the rod back in and transfer the hole all the way through. If you can get clever and get the rod and steel part clamped up in the press that is good too.
Do NOT pilot drill with a #30 or god forbid a #40. Start with at least a 3/16" or so bit. Those little drills tend to stick and then break off in the ti.
I drilled all my landing gear rods, both main and tail, in the V block.
Postby kevinh » Fri Sep 22, 2017 12:51 pm
oh yeah - I did the same as what Bryan described. Works good and easy.
kevinh
Postby Spaceman » Fri Sep 22, 2017 7:28 pm
I got my tail spring drilled last night! Here's a bunch of pictures of how I did it:
https://paegelow.blogspot.com/2017/09/tailwheel-spring-rod-2.html
Bryan I immediately forgot what you said and used a 1/8" bit for the pilot holes. Luckily nothing got stuck, it just took a while!
Chris Paegelow
Spaceman
Postby Rick524 » Sat Sep 23, 2017 12:42 pm
Just wanted to say, you are doing a nice job and I enjoy your blog. I'm looking
forward to seeing how the flaps connect to the actuator. Maybe its a mod I
could do to my A Sonex.
Rick
Sonex 524
Rick524
Postby Spaceman » Sat Sep 23, 2017 9:29 pm
Thanks! I'm interested to see how the flaps end up too, obviously they're different from the stock legacy setup. It actually looks pretty simple in the plans; I'll take a picture of it later.
Chris Paegelow
Spaceman
Users browsing this forum: Bing [Bot] and 53 guests
