fastj22 wrote:I look forward to a successful engineering of a BRS into a Sonex. I haven't been able to figure out how to do it. But if someone cracks that egg, I'm listening.
I did find out an interesting tidbit about BRS in ultralights. At Airventure, was looking at several new designs and most had BRS. Seemed these fly low and slow, don't do aerobatics, don't tend to fold up in flight. So why the BRS? You lose your engine, just land. Well, it seems that to qualify for 103, empty weight is key. But they give you a 50lbs allowance for safety equipment. Well, seems most BRS weigh around 20 lbs so that gives you 30 lbs extra to add to other stuff like engines and maintain 103 compliance.
fejmather wrote:Is there any reason a BRS can't be installed far off cg? I don't think it would be fun to drift back to earth nose down or tilted off center, but if you're incapacitated or structurally unsound it seems better than the alternative...
You'd probably suffer some aircraft damage but you'd get all the life saving benefits of a BRS system.
