Tapatalk
Thu Nov 10, 2011 9:18 pm
by chris
SonexBuilders.net is now available on
Tapatalk. Tapatalk is a forum viewing application for iOS, Android and Blackberry.
Tapatalk
Sat Dec 03, 2011 2:46 pm
by Sonex1517
Chris - the avatar limit is very low from Tapatalk on Sonexbuilders - other forums I use from Tapatalk have a little larger file limit....can you check if this is something you can increase a bit? I think the limit is around 6k right now....
Chicagoland
Aerovee/taildragger
Starting on the wings
Re: Tapatalk
Sat Dec 03, 2011 4:08 pm
by chris
I increased the file size to 16k. Let me know if that works better for you.
Sent from my DROID BIONIC using Tapatalk
Tapatalk
Sat Dec 03, 2011 4:22 pm
by Sonex1517
Thanks Chris!
Chicagoland
Aerovee/taildragger
Sat Mar 29, 2014 5:24 pm
by seanmb
When I loaded the forum in Tapatalk I received a dialog box indicating that the Tapatalk api was expired and that if I was the forum admin I should upgrade the api installed in the forum. Everything seems functional.
Sent from my SM-N900P using Tapatalk
Re: Tapatalk
Sat Mar 29, 2014 9:47 pm
by chris
Thanks, I'll check it out.
