New member from Louisiana
Postby buffmaintainer » Tue Jun 16, 2020 9:01 pm
Hey everyone, Names Brandon. I'm finishing up my Eric Witherspoon Sonex, N815EC. It was given to me after a rough landing which resulted in a low RPM prop strike in the dirt and a slightly bent landing leg. I've been rebuilding the whole aircraft and making it mine. I've performed runout checks on the Jabiru 3300 engine, Which were in spec. Ive replaced the flange bolts and crank bolts, I also did all the upgrades as well as replace ignition and high wear components. Engine and airframe time is 250 hours since new. Excited to learn what I can.
Brandon
buffmaintainer
Re: New member from Louisiana
Postby Sonex1517 » Tue Jun 16, 2020 9:14 pm
Welcome Brandon! Good to see you restoring that bird and we look forward to hearing about the first flight!
Return to Introductions
