Plan W05 hinge rivet count
PostPosted: Sun Jul 31, 2011 10:35 pm
by dbdevkc
Either I found a discrepancy in my plans or I do not understand something.
Per WIX-W06: 70 pilot holes are drilled in the piano hinge half. On WIX-W05, it calls for 66 rivets. If you account for the fact that you are not counting the 3 rivets that go through both the hinge, skin, and rib (they are already counted in the rib rivet layout section of the drawing), I believe there should be 67 rivets.
It is not in any drawing revision.
Can anyone verify this?
Thanks!
Kevin
Re: Plan W05 hinge rivet count
PostPosted: Mon Aug 01, 2011 10:40 am
by Andy Walker
I have found some other "counting errors" in the plans for rivet numbers in places.
PostPosted: Mon Aug 01, 2011 11:19 am
by N111YX
Sometimes you just have to put rivets where they show rivets regardless of the callout... :o
:D
PostPosted: Mon Aug 01, 2011 12:54 pm
by Andy Walker
N111YX wrote:Sometimes you just have to put rivets where they show rivets regardless of the callout... :o
:D
Yup, that's what I do! ;)
