Plan W05 hinge rivet count
Postby dbdevkc » Sun Jul 31, 2011 10:35 pm
Either I found a discrepancy in my plans or I do not understand something.
Per WIX-W06: 70 pilot holes are drilled in the piano hinge half. On WIX-W05, it calls for 66 rivets. If you account for the fact that you are not counting the 3 rivets that go through both the hinge, skin, and rib (they are already counted in the rib rivet layout section of the drawing), I believe there should be 67 rivets.
It is not in any drawing revision.
Can anyone verify this?
Thanks!
Kevin
[color=#800000]Kevin Conklin
Building Waiex #169
dbdevkc
Re: Plan W05 hinge rivet count
Postby Andy Walker » Mon Aug 01, 2011 10:40 am
I have found some other "counting errors" in the plans for rivet numbers in places.
Andy Walker
Postby N111YX » Mon Aug 01, 2011 11:19 am
Sometimes you just have to put rivets where they show rivets regardless of the callout... :o
:D
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby Andy Walker » Mon Aug 01, 2011 12:54 pm
N111YX wrote:Sometimes you just have to put rivets where they show rivets regardless of the callout... :o
:D
Yup, that's what I do! ;)
Andy Walker
Return to Waiex
