The First 1000 Hours
Postby N111YX » Wed Apr 20, 2022 8:11 pm
I'm posting this in the "Waiex" forum, but it could just as well be in the Jabiru section. I have crossed the 1000-hour mark with the original airframe and engine. I like to keep good records and enjoy the resulting statistics for operational information.
Total tach time hours (“engine on” time): 1000
Total Hobbs Time (taxi and flight) hours: 954
Total Miles (GPS odometer): 111585 statute miles
Operational timeframe: May 20, 2010 – April 19, 2022
Engine (Jabiru 3300A, #1637) AeroShell 15W-50, Napa 1394 oil filter, NGK D9EA plugs, K&N air filter, AeroCarb
Oil changed and analysis done every 25 tach hours, new spark plugs every 50 hours
Maintenance other than oil/plugs/filters/compression checks, ect.
-198 hrs - new exhaust springs, others replaced on condition about every 200 hours
-298 hrs - new ignition caps, rotors
-598 hrs – added washer at relief spring for more oil pressure, new ignition caps, rotors
-778 hrs– new alternator stator and voltage regulator
-850 hrs– replaced ignition coils, new alternator stator under warranty from Jabiru
Airframe (Waiex W0082) Kit delivered February 2007, First flight May, 2010
General maintenance items other than Condition Inspection items-
-141 hrs – upgraded tailwheel and bracket
-161 hrs - removed ventral fin because of taxi damage
-224 hrs - new tires, changed landing gear bolts to cadmium plated from stainless steel
-249 hrs – installed upgraded, larger tailwheel and bracket
-275 hrs – performed Sonex SB 001 (tail modification)
-299 hrs – installed new Prince propeller
-312 hrs – new battery
-399 hrs – new brake pads
-496 hrs – new tires
-555 hrs – performed Sonex SB 002 (new rudder cables)
-700 hrs – replaced Shaw gas cap
-723 hrs – new tires and brake pads
-778 hrs – new battery
-830 hrs – installed GDL 82 ADS-B equipment, new comm and transponder antennas
-900 hrs – new tires
Average tach time between oil changes 24.9
Average Hobbs time between oil changes 22.8
Average compressions over the life of the engine 76/67/68/73/71/70
Average MPG - 23.3
Average Fuel Usage per Hobbs hour – 5.27 gallons per hour
Average speed (GPS odometer based so taxi mileage included) 117.0 mph
Average fuel cost per flight hour - $25.56 (all 100LL @ $4.88 average cost per gallon)
Average number of miles between 25 tach hour checks – 2578 statute miles
Average gallons used per 25 tach hours – 119.1
Total Landings - 1359
326 different airports visited
117 passengers
The Jabiru manual calls for a top overhaul at 1000 hours. I have ordered a new engine rather than perform the top overhaul as I have not done any of the engine updates that have been issued. I plan to sell the original engine when I get the new one and that will likely be cheaper overall versus overhauling and updating the old engine.
A new engine has been on order since October 2021 and there is no firm date for the shipment of the new one so I will keep on flying #1637. All of the compressions are good and the oil analysis is clean.
Here's a list of where I've been!
1 (D73) Monroe, GA
2 (WDR) Winder, GA
3 (AHN) Athens, GA
4 (19A) Jackson Co., GA
5 (IIY) Washington-Wilkes Co. GA
6 (CVC) Covington, GA
7 (GVL) Gainesville, GA
8 (3J7) Greensboro, GA
9 (EBA) Elberton, GA
10 (9A0) Dahlonega, GA, Wimpys
11 (LZU) Lawrenceville, GA
12 (18A) Franklin Co. GA
13 (MLJ) Milledgeville, GA
14 (CEU) Clemson, SC
15 (GA2) Peach State Airport, GA
16 (OPN) Thomaston, GA
17 (PDK) Atlanta, Dekalb Peachtree
18 (FFC) Peachtree City, GA
19 (PUJ) Paulding Co. Airport, GA
20 (4A4) Cedartown, GA
21 (RMG) Rome, GA
22 (2M2) Lawrenceburg, TN
23 (TKX) Kennett, MO
24 (2MO) Mt. Vernon, MO
25 (SGF) Springfield, MO
26 (HFJ) Monett, MO
27 (LWC) Lawrence, KS
28 (OJC) Olathe, KS, Johnson Co. Industrial
29 (TOP) Topeka, KS, Billard
30 (MXO) Monticello, IA
31 (OSH) Oshkosh, WI
32 (ETB) West Bend, WI
33 (EYE) Eagle Creek, Indianapolis, IN
34 (LOU) Louisville, Bowman Field, KY
35 (4A9) Fort Payne AL
36 (DCU) Decatur, AL
37 (RYY) Marietta, GA
38 (BGF) Winchester, TN
39 (SYI) Shelbyville, TN
40 (3M5) Huntsville, AL, Moontown
41 (65J) Wrens, GA
42 (CSV) Crossville, TN
43 (52A) Madison, GA
44 (DNL) Augusta, GA, Daniel
45 (TOC) Toccoa, GA
46 (AYS) Waycross, GA
47 (X35) Dunellon, FL
48 (LCQ) Lake City, FL
49 (AJR) Cornelia, GA
50 (MAC) Macon, GA, Smart Field
51 (DBN) Dublin, GA
52 (EZM) Eastman, GA
53 (AND) Anderson, SC
54 (CCO) Newnan, GA
55 (LGC) La Grange, GA
56 (CSG) Columbus, GA
57 (ZPH) Zephyrhills, FL
58 (LAL) Lakeland, FL
59 (PCM) Plant City, FL
60 (LUX) Laurens Co., SC
61 (LHZ) Louisburg, NC
62 (SFQ) Suffolk, VA
63 (FFA) Kitty Hawk, NC
64 (MQI) Manteo, NC
65 (HRJ) Erwin Co., NC
66 (TUP) Tupelo, MS
67 (HOT) Hot Springs, AR
68 (MLC) McAlester, OK
69 (OUN) Norman, OK
70 (AMA) Amarillo, TX
71 (TCC) Tucumcari, NM
72 (AEG) Double Eagle, Albuquerque, NM
73 (INW) Winslow, AZ
74 (FLG) Flagstaff, AZ
75 (HND) Henderson, NV
76 (REI) Redlands, CA
77 (AVX) Catalina Island, CA
78 (TRM) Thermal, CA
79 (BXK) Buckeye, AZ
80 (DVT) Phoenix (Deer Valley), AZ
81 (0E0) Moriarty, NM
82 (TDW) Amarillo (Tradewinds), TX
83 (SGT) Stuttgart, AR
84 (CMD) Cullman, AL
85 (JFX) Jasper, AL
86 (HEE) West Helena, AR
87 (UTA) Tunica, MS
88 (BPK) Mountain Home, AR
89 (M22) Russellville, AL
90 (PYP) Centre, AL
91 (K24) Jamestown, KY
92 (AAS) Campbellsville, KY
93 (DNV) Danville, IL
94 (ARR) Aurora, IL
95 (C59) Delavan, WI
96 (EXK) Elizabethtown, KY
97 (CZL) Calhoun, GA
98 (HZD) Huntingdon, TN
99 (MNF) Mountain View, MO
100 (90KS) Sunset Strip, Topeka, KS
101 (MHK) Manhattan, KS
102 (K59) Atchison, KS
103 (AIZ) Kaiser/Lake Ozark, MO
104 (PHT) Paris, TN
105 (THA) Tullahoma, TN
106 (MDQ) Madison Co, Huntsville, AL
107 (CNI) Cherokee, Co., Canton, GA
108 (SC00) Triple Tree Aerodrome, Woodruff, SC
109 (DZJ) Blairsville, GA
110 (BHC) Baxley, GA
111 (MLB) Melbourne, FL
112 (CDK) Cedar Key, FL
113 (CTY) Cross City, FL
114 (GMU) Greenville SC, Downtown
115 (ACJ) Americus, GA
116 (HBI) Asheboro, NC
117 (ECP) Panama City Beach, FL
118 (MRN) Morganton, NC
119 (BCB) Blacksburg, VA
120 (MRB) Martinsburg, WV
121 (FDK) Frederick, MD
122 (EVY) Middletown, DE
123 (N87) Robbinsville, NJ
124 (DXR) Danbury, CT
125 (SFZ) Pawtucket, RI
126 (FIT) Fitchburg, MA
127 (LCI) Laconia, NH
128 (PWM) Portland, ME
129 (MPV) Montpelier, VT
130 (FZY) Fulton, NY
131 (IAG) Niagara Falls, NY
132 (ERI) Erie, PA
133 (S24) Fremont, OH
134 (FNT) Flint, MI
135 (MGC) Michigan City, IN
136 (GRB) Green Bay, WI
137 (HXF) Hartford, WI
138 (2R2) Indianapolis, Hendricks Co., IN
139 (RKW) Rockwood, TN
140 (VPC) Cartersville, GA
141 (SZY) Selmer, TN
142 (CRX) Corinth, MS
143 (0GE5) Mountain Airpark, Cleveland, GA
144 (PIM) Pine Mountain, GA
145 (4A7) Hampton, GA
146 (4A0) Berry Hill Airport, Stockbridge, GA
147 (VDI) Vidalia, GA
148 (09J) Jekyll Island, GA
149 (JES) Jesup, GA
150 (FZG) Fitzgerald, GA
151 (6A2) Griffin, GA
152 (DYA) Demopolis, AL
153 (MLU) Monroe, LA
154 (CCA) Clinton, AR
155 (EMP) Emporia, KS
156 (GBD) Great Bend, KS
157 (IML) Imperial, NE
158 (STK) Sterling, CO
159 (LAR) Laramie, WY
160 (RKS) Rock Springs, WY
161 (OGD) Ogden, UT
162 (TWF) Twin Falls, ID
163 (LGD) La Grande, OR
164 (ALW) Walla Walla, WA
165 (COE) Coer D’Alene, ID
166 (HLN) Helena, MT
167 (BIL) Billings, MT
168 (HEI) Hettinger, ND
169 (ABR) Aberdeen, SD
170 (ANE) Anoka, MN
171 (STE) Stevens Point, WI
172 (GGP) Logansport, IN
173 (JAU) Jacksboro, TN
174 (TZV) Tompkinsville, TN
175 (2I3) Falls of Rough, KY
176 (2A0) Dayton, TN
177 (GZS) Pulaski, TN
178 (POF) Poplar Bluff, MO
179 (CGI) Cape Girardeau, MO
180 (DNN) Dalton, GA
181 (GA80) Conyers, Whispering Pines Airpark, GA
182 (DQH) Douglas, GA
183 (LEE) Leesburg, FL
184 (INF) Inverness, FL
185 (TMA) Tifton, GA
186 (9A5) Lafayette, GA
187 (H21) Camdenton, MO
188 (IOW) Iowa City, IA
189 (PCZ) Waupaca, WI
190 (FKR) Frankfort, IN
191 (SCX) Oneida, TN
192 (1A5) Macon Co., Franklin, NC
193 (APT) Marion Co. Jasper, TN
194 (H88) Fredericktown, MO
195 (OWI) Ottawa, KS
196 (BUM) Butler, MO
197 (UCY) Union City, TN
198 (FYM) Fayetteville, TN
199 (BRY) Bardstown, KY
200 (IKK) Kankakee, IL
201 (MLI) Moline, IL
202 (OTM) Ottumwa, IA
203 (EIW) New Madrid, MO
204 (DYR) Dyersburg, TN
205 (9FL0) Suwanee Belle, FL
206 (18GA) Sleepy Hollow, Social Circle, GA
207 (42J) Keystone Airpark, FL
208 (SEF) Sebring, FL
209 (X07) Lake Wales, FL
210 (VLD) Valdosta, GA
211 (48A) Cochran, GA
212 (GE05) Gibson Field, GA
213 (GTK) Pigeon Forge, TN
214 (GLW) Glasgow, KY
215 (BMI) Bloomington, IL
216 (UNU) Juneau, WI
217 (RZL) Rensselaer, IN
218 (EKQ) Monticello, KY
219 (Hodges) Hodges Field, Americus, GA
220 (FTY) Fulton Co. Airport, Atlanta
221 (LQK) Pickens Co, SC
222 (TVI) Thomasville, GA
223 (VDF) Tampa Executive
224 (FQD) Rutherfordton, NC
225 (24A) Jackson Co., NC
226 (MCN) Macon, GA
227 (GA06) Monticello, GA
228 (49A) Ellijay, GA
229 (AKH) Gastonia, NC
230 (1A3) Copper Hill, TN
231 (RHP) Andrews, NC
232 (JZP) Pickens Co, GA
233 (CTJ) Carollton, GA
234 (RNC) Mc Millan, TN
235 (4A6) Scottsboro, AL
236 (M04) Covington, TN
237 (PLK) Branson, MO
238 (3DW) Springfield, MO Downtown
239 (AMW) Ames, IA
240 (IFA) Iowa Falls, IA
241 (MCW) Mason City, IA
242 (SGS) South St Paul, MN
243 (21D) Lake Elmo, MN
244 (ISW) Wisconsin Rapids, WI
245 (BCK) Black River Falls, WI
246 (FOD) Fort Dodge, IA
247 (CHT) Chillicothe, MO
248 (DMO) Sedalia, MO
249 (3M0) Gastons, AR
250 (JBR) Jonesboro, AR
251 (8A1) Guntersville, AL
252 (PRN) Greenville, AL
253 (5R2) Ocean Springs, MS
254 (4R9) Dauphin Island, AL
255 (EDN) Enterprise, AL
256 (FGU) Collegedale, TN
257 (DKX) Knoxville Downtown Island
258 (MSL) Muscle Shoals, AL
259 (M01) Dewitt Spain, Memphis, TN
260 (FYV) Fayetteville, AR
261 (CNU) Chanute, KS
262 (DXE) Dexter, MO
263 (CHA) Chattanooga, TN
264 (AIK) Aiken, SC
265 (5GA) Elliot Field, Dawsonville, GA
266 (SSI) St Simons Island, GA
267 (07A) Hendersonville, NC
268 (8A3) Livingston, TN
269 (BWG) Bowling Green, KY
270 (HKY) Hickory, NC
271 (0V4) Brookneal, VA
273 (RMN) Stafford, VA
274 (W13) Waynesboro, VA
275 (MTV) Martinsville, VA
276 (IPJ) Lincolnton, NC
277 (OKZ) Sandersville, GA
278 (2J3) Louisville, GA
279 (2J5) Millen, GA
280 (BXG) Waynesboro, GA
281 (AGS) Augusta, GA
282 (S17) Twin Lakes, SC
283 (S19) Mc Cormick, SC
284 (GRD) Greenwood, SC
285 (EOE) Newberry, SC
286 (FDW) Winnsboro, SC
287 (T73) Kirk Air Base, SC
288 (LKR) Lancaster, SC
289 (DCM) Chester, SC
290 (35A) Union, SC
291 (5A9) Warm Springs, GA
292 (AUO) Auburn, AL
293 (06A) Tuskegee, AL
294 (6A1) Butler, GA
295 (2GA0) Kennedy Field, GA
296 (RZR) Cleveland, TN
297 (92A) Chilhowee, TN
298 (MNV) Madisonville, TN
299 (TYS) Knoxville, TN
300 (7A8) Avery County, NC
301 (6A4) Mountain City, TN
302 (VJI) Virginia Highlands, VA
303 (0A9) Elizabethton ,TN
304 (GCY) Greenville, TN
305 (UKF) North Wilkesboro, NC
306 (HSP) Hot Springs, VA
307 (CBE) Cumberland, MD
308 (UNV) State College, PA
309 (LHV) Lock Haven, PA
310 (UCP) New Castle, PA
311 (3W2) Put in Bay, OH
312 (RNP) Owasso, MI
313 (IKW) Midland, MI
314 (LWA) South Haven, MI
315 (LOT) Romeoville, IL
316 (RYV) Watertown, WI
317 (C47) Portage, WI
318 (RAC) Racine, WI
319 (TYQ) Indianapolis, Executive
320 (2A1) Jamestown, TN
321 (16J) Dawson, GA
322 (F47) St George Island, FL
323 (AAF) Apalachicola, FL
324 (2J9) Quincy, FL
325 (BGE) Bainbridge, GA
326 (9A9) Marion, NC
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Re: The First 1000 Hours
Postby nwawingman » Wed Apr 20, 2022 10:17 pm
Wonderful information. You never stop inspiring us Kip!
Rick Wantz - Arkansas
Sonex 367 T/W AeroVee/Aeroinjector - Prince Elliptical Prop <361hrs
1st Flight 7/13 KOSHX3 Young EaglesX14
http://www.mykitlog.com/wingman
https://www.youtube.com/channel/UC2TNLK ... A63FvnPkNA
nwawingman
Postby jowens » Wed Apr 20, 2022 10:30 pm
Great information!! Thanks for sharing!!
Jim Owens
jowens
Postby GraemeSmith » Thu Apr 21, 2022 7:09 am
So..........you don't fly much....... ;-)
Seriously - nice!
Return to Waiex
