Ruddervator questions
Postby Bryan Cotton » Fri Nov 08, 2013 11:06 pm
Hi all,
A couple of ruddervator questions. The skins are trimmed at a 20 degree angle, but then the tip rib leans in a bit. It seems like I should mark the 20 degrees on the bottom, then mark over the little bit of lean in the front, then connect the lines across the top. Does this sound right?
Also I did not see a bend radius callout on the drive horns. I am thinking to use 1/8" times 4, or a half inch radius. That would be a 1" pipe, same as the hockey stick. What did you do?
Thanks!
Re: Ruddervator questions
Postby N111YX » Sat Nov 09, 2013 8:25 pm
I'd be happy to help, Bryan but I'm not sure what you mean regarding the first paragraph. I'll get my plans out tomorrow. We're going back about five years for me here.
I don't recall the horn radius but it can be large as it does not have to fit with anything...
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Return to Waiex
