Area 51% wrote:How come social convention dictates dropping the flap on a heavy wing (thereby increasing drag) instead of reflexing the flap on the light wing? Is it not possible due to interference between the top of the flap and rear spar?
Speaking of interference...Be careful adjusting the rudder to an off-center position in relation to neutral ruddervators. I had an issue with the bottom forward edge of the ruddervators contacting the rear spar before the rudder got to it's stops. I'm thinking you might introduce that contact on one side with an offset rudder. The only way I was able to overcome that contact was by decreasing the overall down deflection by a degree.
