Wingtip Light Placement
Postby Spaceman » Thu Aug 31, 2017 4:27 pm
What's up guys, I'm just about done with my second wing, and getting ready to fit the wintip next. I noticed on another thread the other day (now I can't find it of course), someone mentioned they had issues getting their plane inspected because their wingtip lights weren't visible from above or something like that.
I already did the wingtip on my other wing, and I hadn't even thought about visibility from the top. I just located the light right in the middle of the fiberglass wingtip. I have the little gaugepod fairings that push the lights out a little, but I still don't think they'll be visible from above. I'll post a picture when I get home from work.
Is it really a requirement to have the lights visible from above? I didn't think lights were really even required in the first place, I was just doing it for extra safety!
If I do need lights visible from above, I guess my options would be to redo my first wingtip completely, relocate the light and patch the hole I cut in the fiberglass, or just leave it and add a third light on top of the fuselage or something!
Chris Paegelow
http://paegelow.blogspot.com/
Spaceman
Re: Wingtip Light Placement
Postby Spaceman » Thu Aug 31, 2017 7:27 pm
Here are a couple pictures of the RH wingtip, which is the one I did a few months ago. The light isn't installed on the fairing here, but you can see it still won't really stick out past the top edge of the wing!
Chris Paegelow
Spaceman
Postby kevinh » Thu Aug 31, 2017 10:05 pm
Yah - check the FARs for the angle of view rules for the wingtip lights. It is something like 30 (45? - can't remember) deg above and below and the white must be viewable also above and below and x (60?) deg from the tail center line.
Mounting the lights in the middle of a sonex wingtip won't cut it. For my wingtips I will be mounting the lights at the top edge with a little 3d printed fairing/mount.
kevinh
Postby Spaceman » Sun Sep 03, 2017 9:22 pm
Yeah I think you're right. I just did my other wingtip today, and I had to put the light mount all the way at the top/outboard edge for it to be visible from above. I'll post some pictures later. Now I'll have to go back and change the first one!!
Chris Paegelow
Spaceman
Postby mike.smith » Sun Sep 03, 2017 10:11 pm
Postby Spaceman » Wed Sep 06, 2017 10:47 pm
Thanks for the info Mike!
I forgot to come back and post pictures. Here's how I did my left wing (the second wing I built):
This allows the light to peek out just past the top of the wing, so I think it'll be visible up to 90° above. This view is from the floor looking up, since the wing was upside down on the table:
To fix the right wingtip, I cut a new hole behind the updated light location first, so I could reach the back of the old hole through it. I used a piece of waxed aluminum plate as a backer on the outside, and then applied fiberglass on the inside of the old hole. I used a little fiberglass repair kit from Autozone, and I was able to get 12 layers out of the piece of fabric it came with. I think it turned out pretty sturdy, but it'll need some filling and sanding later. If I decide I really hate it I can fit a whole new wingtip later on, but this cost me $20 and like an hour versus $100+ and several hours to fit a new wingtip!
Chris Paegelow
Spaceman
Postby Spaceman » Wed Sep 06, 2017 10:48 pm
Also, I didn't really mean to post this in the Waiex forum since it isn't Waiex specific... If any mods want to move this thread somewhere more appropriate that's fine with me!
Chris Paegelow
Spaceman
Return to Waiex
