Acceptable edge distance
Posted: Sat Jun 25, 2016 7:27 am
Clecoed the stabilators to the Y-fitting and have the hockey sticks resting on the longerons. The attaching angle that will ultimately connect the "sticks" together, and hold them down to the longerons, came pre-pilot drilled in the machined angle kit. When clamped to the hockey sticks and centered, the 1/4in. bolts that holds everything down, will have only 1/8in. from the edge of the hole to the inside edge of the longeron.
Is this an acceptable edge to hole distance, or should I consider remaking the angle with the hole spacing wider?
I am in posession of the Aircraft Standard Handbook, but can't seem to find any info on the matter.
