Ruddervator horns
PostPosted: Fri Apr 15, 2016 10:17 pm
by tommywatson
Hello Waiex people,
I'm about to bend my control horns, I was wonrding if the wisdome here could tell me if this is the right direction? https://goo.gl/2xS5gi
I've looked at the plans and they say "down" and this would be correct but I can't match this up with what I'm seeing on the 3 view underneath...
Thanks!
Re: Ruddervator horns
PostPosted: Sat Apr 16, 2016 12:02 am
Tommy,
That was how I did mine. Scroll down a bit on my page 3:
viewtopic.php?f=39&t=578&hilit=Ruddervator&start=20
PostPosted: Sat Apr 16, 2016 8:49 am
by tommywatson
Thanks Bryan, I missed that picture when I scrolled through last night.
Appreciated!
PostPosted: Sat Apr 16, 2016 11:07 am
by John Usher
Tommy,
Hope this helps:
PostPosted: Sat Apr 16, 2016 5:14 pm
by tommywatson
Yup, thanks John!
PostPosted: Thu Apr 21, 2016 8:01 pm
by Area 51%
Watch out for the angle. Seems to me there was an update on the service bulletin. You will be under-sized unless your plans have been changed.
PostPosted: Thu Apr 21, 2016 9:28 pm
by kevinh
yep. plans say 15 deg, but the update corrects it to 20 deg. Definitely worth going through all of the bulletins on the website and marking up your plans in advance.
PostPosted: Sun Apr 24, 2016 12:07 pm
by tommywatson
Thanks guys, I checked the updates for my kit, I bent everything to 20 degrees, turned the first set of hockey sticks into scrap by over tweaking them to about 25 degrees, the second set worked out ;-)
PostPosted: Sat Sep 03, 2016 5:02 am
by EineBeBoP
Area 51% wrote:Watch out for the angle. Seems to me there was an update on the service bulletin. You will be under-sized unless your plans have been changed.
D'oh. Just bent these to the 15 in the plans yesterday. Looks like its back to the shop to bend them a bit further.
