trim install
trim install
Postby caymancraig » Fri Jul 10, 2015 5:46 pm
In reference to the standard dial-a-trim, where do you set the springs up in the initial installation? Stick in the middle? etc? Do you put any tension on the springs at first?
Craig Mock
Waiex - N239YX
Tri-gear, turbo, Dynon panel
Naples, Fl
caymancraig
trim install
Postby Sonex1517 » Fri Jul 10, 2015 6:25 pm
Caymancraig
I could be mistaken but I believe the installation manual specifically tells you how to set it up.
The manual is here if you don't have it
http://www.aeroconversions.com/support/manuals.html
Re: trim install
Postby caymancraig » Fri Jul 10, 2015 8:14 pm
Amazing how helpful instructions are.....guess the dog ate mine. Thanks so much for the info, I look at them and they answer so many questions!!
Craig Mock
Waiex - N239YX
Naples, Fl
caymancraig
trim install
Postby Sonex1517 » Fri Jul 10, 2015 9:02 pm
Been there! (We have two dogs)
Chicagoland
N1517S reserved
Return to Waiex
