Waiex Build Status and Completion Photos
Re: Waiex Build Status and Completion Photos
Postby Andy Walker » Thu Oct 13, 2011 8:04 am
Hey Mike...
I'm currently thinking about placement of my (Van's) NACA vents...how did you decide where to place yours, and how are you routing any tubing to reach the actual vents? I'd like to run tubing to vents in the panel, but as Kip pointed out to me it can be a challenge to do so while avoiding conflicts with the flap & brake handles and other essential areas. If I can't figure it out I'll just put eyeballs directly on the ends of the NACA vents, but then the air is blowing on your legs instead of your face, which is a big difference in summer in Georgia. :lol:
Andy Walker
Postby MichaelFarley56 » Thu Oct 13, 2011 5:14 pm
Hi Andy,
A lot of my NACA placement was by eyeball with the thought of getting them as high as possible to avoid brake and flap handle interference. With that in mind I also pushed them as far forward as possible, getting them close to that vertical angle. (sorry, I don't have my plans but it's the channel that the rudder bars attach to). I don't have my panel installed yet (working on it) but once done there will only be around 12" or so of flexible tubing needed to go from the vent to the other one in my panel. I'm hoping to keep the hose high enough that there won't be any interference, but it will be close. I'll hopefully be able to tell you more in a week or two, once my panel is installed.
Postby Andy Walker » Fri Oct 14, 2011 12:56 pm
MichaelFarley56 wrote:Hi Andy,
Cool, thanks. I hope the fuel tank doesn't get in the way! I was thinking as you are; as high as far forward as possible seems to be the way to go.
Andy Walker
Postby MichaelFarley56 » Sat Nov 19, 2011 7:10 pm
Hey all, just as a quick update I'm still hacking away at #0056 with hopes that the end is slowly getting closer. Lately I've been working on wiring and engine baffles, both being a lot of fun! (sarcasm...)
Anyway, the controls are now on:
The wingtips minus final light wiring is done:
And I think I just about have the baffles done. I had to trim a lot of the side baffle pieces as well as the oil cooler pieces, but it's getting there:
After some final cowling tweaking I hope to finish the wiring, rivet the panel in place and try to get this thing running. If anyone wants to help by keeping Ohio warm a little bit longer I would appreciate it :D
Postby N111YX » Sun Nov 20, 2011 11:13 am
Looks great...:)
Thanks for the update...!
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby 142YX » Sat Nov 26, 2011 2:06 pm
I installed my seat last night.. ended up modifying it from the plans a bit to get a nice fit. My seat ended up being 1/2 inch higher than called out which i am OK with. I modified the 1.25" dimension for the middle piano hinge distance to .75". This gave me a really nice fit with out having to trim & check a hundred times, the existing center cutout worked. I don't see how the seat would fit in place with the clearance hole for the seatbelt brackets, per plans. Also the "Clips" (WIX-F10-08) needed to be trimmed.. no way the seat would go in without doing that.
450 hours and counting..
142YX
Postby N111YX » Sun Nov 27, 2011 12:18 am
That's perfect. The first time a 200 lb passenger steps in your seat and concentrates all of that weight in one spot, you'll be glad that you had a bit of clearance before the pan hits your lower structure...:)
The workmanship look great...!
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby MichaelFarley56 » Sun Nov 27, 2011 1:50 am
N111YX wrote:That's perfect. The first time a 200 lb passenger steps in your seat and concentrates all of that weight in one spot, you'll be glad that you had a bit of clearance before the pan hits your lower structure...:)
If that was me (and it probably was) my apologies...
Postby 142YX » Sun Nov 27, 2011 6:57 am
N111YX wrote:The workmanship look great...!
Thanks! I experienced quite the learning curve with my good friend, the fly cutter, chucked into a hand drill when cutting out those control stick holes..
Due to my seat mod, the front part of the seat also ended up being .25~.5 inches farther forward on the spar box than the plans state.. i am nervous that i will have an annoying job of hole enlarging in store for me when i install the control stick assembly.
I am curious, how much clearance do you have between your control stick and the aft edge of the cutout at full aft elevator deflection?
142YX
Postby N111YX » Sun Nov 27, 2011 11:43 am
I must have forgot to add that to my "problems" forum.
I probably enlarged the seat pan holes 30% of what is shown in the plans. I'm not sure what stick movement range the factory were using but it was way off. It's not a big deal, the pan comes out pretty easily so when you get your control system in you can just trim the holes as you move the sticks to the stops...:)
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1175 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Return to Waiex
