pitot and static location
Re: pitot and static location
Postby Bryan Cotton » Fri Nov 25, 2016 10:02 am
Thanks Kip!
Postby Bryan Cotton » Tue Dec 13, 2016 12:15 am
Plumbing progress. Discovered that if you spray WD40 on a paper towel, then wipe the tube with it, it slides like magic through the grommets. Here in the tail I made all the holes in one line.
Here the tube exits the tail and heads for an elbow fitting.
Out the bottom of the elbow and through a guide that keeps it free from the controls.
Then it runs forward:
Postby Concorde » Tue Dec 13, 2016 8:20 am
Looking good.
Ben
Sonex # 1684
Tri-Gear, Dual Control
Rotax 912uls
N379BS reserved.
Concorde
Postby WaiexB22 » Mon Apr 15, 2024 1:26 pm
So...8 years later, any issues with the pitot tube on the tail?
I am considering this because I like that it is up off the ground, but it seems like it could be an eye poker, especially for kids.
Robert
Waiex-B 0022
Yamaha Apex
Building
WaiexB22
Postby Area 51% » Mon Apr 15, 2024 2:30 pm
I too plagiarized Kip's installation on my first Waiex, and have installed the same setup on Number Two.
The tube's ability to blind a person of the correct height is not trivial. But to keep ocular fluid off the tube and bugs out of the pitot, the installation of a short tube with a rivet pressed in the end, put in place when not actively flying, will keep hospital visits to a minimum. .
Postby WaiexB22 » Mon Apr 15, 2024 2:44 pm
Thanks for the tips! I am going to do it, but I am going to put it on the pilot side. I am planning a tip back canopy and having it on my side would keep any passengers away and keep it on my side for easier preflight inspection.
Robert
Waiex-B 0022
Yamaha Apex
Building
WaiexB22
Postby Bryan Cotton » Mon Apr 15, 2024 3:16 pm
WaiexB22 wrote:So...8 years later, any issues with the pitot tube on the tail?
I like my tail mounted pitot probe. I'm not sure I have great static pressure in the cabin though.
At fly-ins I pull the pitot out, so no eyes are poked or tubes bent.
Postby WaiexB22 » Mon Apr 15, 2024 4:33 pm
What diameter tubing are you running Bryan? Did you have issues that made you believe you don't have adequate static pressure?
Robert
Waiex-B 0022
Yamaha Apex
Building
WaiexB22
Postby BobDz » Mon Apr 15, 2024 4:54 pm
Just curious...
Bryan, why did you decide on this location instead of the more traditional under the wing location? Is there an advantage?
Bob Dz...
Sonex B, Tri-gear
N624DZ (reserved)
BobDz
Postby Bryan Cotton » Mon Apr 15, 2024 5:13 pm
Our altitude seems off from what ATC says we are at. That could be an issue with our MFD. I'm not sure. I think we used 1/4" OD nylaflow tubing from Spruce.
We chose the tail mounted pitot for 3 reasons:
1) I thought Kip's setup looked cool
2) I thought the pitot probe under the wing could be prone to damage
3) After we closed the wings, I found the mounts for the pitot static tubing still inside a plastic bag. We forgot to install them.
Return to Waiex
