Trim system
Re: Trim system
Postby Tony4aro » Tue Aug 22, 2023 9:08 pm
Panther16 wrote:On the Sonex the D180 haas 2 inputs for the tach. I take 1 off the left mag and the other off the Jabiru alternator.
On the Panther I have GRT 6 cylinder EIS and take the tach signal off the rear mounted SPA alternator.
ok.... great. I have the rear SPA alternator also. did you just hook the tach to one of the yellow wires? or is there something else inline?
Corvair powered Waiex (under construction)
N3848D
W0181
Tony4aro
Re: Trim system
Postby Panther16 » Wed Aug 23, 2023 11:18 am
I checked W&B for both engines. Aerovee install empty weight 688. For Jabiru 3300 install 698.
As for tach may need a resistor in line, should be in instructions for instrument you are using. You have 50% chance of picking correct output lead of alternator, only 1 will work. If it doesn’t work switch to other output lead.
Panther16
Re: Trim system
Postby Tony4aro » Wed Aug 23, 2023 5:06 pm
Panther16 wrote:As for tach may need a resistor in line, should be in instructions for instrument you are using. You have 50% chance of picking correct output lead of alternator, only 1 will work. If it doesn’t work switch to other output lead.
OK.... thanks for the info.
N3848D
W0181
Tony4aro
Return to Waiex
