Balanced my ailerons tonight... or should I say found out they were already balanced. I hung them next to each other (using ratchet straps to control height and kite string through the hinge pins), leveled them in all directions along the tops, then inspected their hang relative to each other. I could not detect any difference between them, so I guess they're all set! Hooray for no more drilling in lead!
Aerobatic ailerons. Plans call for them to hang the same relative to each other (versus standard ailerons, which balance each individually to hang along a level plane.)
For size reference, in the first picture you can see the small drive horn sticking out of the back of the aileron... that's where normal ailerons would end. Quite a bit more skin and another rib on the aerobatic (plus the drive horn gets 2 ribs rather than 1. Apparently that's a lot more weight versus the same counterweight lead.
- 20140303_174840.jpg (252.77 KiB) Viewed 8366 times
- 20140303_175744.jpg (227.68 KiB) Viewed 8366 times
- 20140303_174816.jpg (218.29 KiB) Viewed 8366 times
- 20140303_175758.jpg (198.23 KiB) Viewed 8366 times
