by Bryan Cotton » Sun May 11, 2014 10:53 am
A quick follow up- I was able to set the rivets with the doubler bolted in. I did two things - first I put some masking tape over a gasket scraper, and used that to flex the flange away from the doubler a bit. Also, I set the rivet a little, pushed it in more flush, set it a little more, pushed in again and then was able to set it home. Go slow and use the hand puller. The trick is that when you start setting the rivet the whole shank swells, so if you go too crazy you will get a big gap under the head.
