lutorm wrote:The linked post also says it's fine to run it briefly at WOT without the cowling.
I personally think the risk is overblown;
SonexN76ET wrote:Noel,
You must have misunderstood Sonex on running the engine with the cowling off. Check Joe Norris's earlier post on it from about a year ago on this forum.
http://www.sonexbuilders.net/viewtopic.php?f=33&t=2465&p=18432&hilit=without+cowling#p18427
Jake
Sonerai13 wrote:Running on the ground for short periods of time without the cowling is ok. You just don't want to run it too long, and only VERY briefly at high power settings. You have to do this in order to dial in the AeroInjector, but just use your best judgement and keep it to a minimum.
DCASonex wrote:Scored a cylinder two years ago when during my BFR, examiner asked for full power on stall.
Users browsing this forum: Google Adsense [Bot] and 1 guest
